150 shot on stock fuel pump?
Old 08-03-2006, 07:12 PM
BLACKDEATH's Avatar
Default 150 shot on stock fuel pump?
is ok to run a 150 shot on a stock fuel pump? its on a 96 camaro with 59,000 miles, i have a fuel pressure safty switch.............
thanks
Old 08-03-2006, 07:31 PM
Jditlfm's Avatar
you can, I would recomend upgrading anyway for added saftey. You will be pushing the limits of the stock one. I would just look at it as it being easier and cheaper to replace a fuel pump then an engine. Going with a Nitrious set up isn't something you wanna cheap out on. I will say though chances are you will be pretty safe with a fuel pressure saftey switch though, it's your call.
Old 08-03-2006, 07:34 PM
buffman's Avatar
Not sure how long the old stocker would last, but I know quite a few people who've run them and havent had a problem. at least you have a fuel pressure safety switch. I run into too many people these days that think Nitrous is a small project. I ask them about safety items, and such, and they just reply "I dont need that stuff, my nitrous is on or off by this switch right here"
Heck a local F-body guy just put juice on his car. I think he's running a 125 shot. No colder plugs, no pulled timing, (it's an Auto), spraying through the shifts. Ohh well I guess
Old 08-03-2006, 07:43 PM
BLACKDEATH's Avatar
yeah, its sucks casue i have alot of big money races setup and and its hot augest nights here in reno so i want to run bigger jets, and i cant get a hold of a fuel pump in time, but its on order it just wont be here until next week.........i have been on a 100 shot for about 2 months and runs really hard, just running some faster cars and just want to make sure i have them coverd lol.............
Old 08-03-2006, 07:45 PM
BLACKDEATH's Avatar
plus i have 2 degrees of timing pulled.............i did everything right i wanst a cheap *** on the nitrous kit lol............
Old 08-03-2006, 07:46 PM
Jditlfm's Avatar
I think you will be allright for a little while as long as the saftey switch is in and you plain on upgrading the fuel pump.
Old 08-03-2006, 07:47 PM
BLACKDEATH's Avatar
oh yeah and i have 110 octane
Old 08-03-2006, 09:17 PM
96capricemgr's Avatar
Can you get the wiring upgrade in time???? It will helpout the stock pump a lot. I think the hit is going to trigger the safety switch and the spray will be incosistent. What happens is the sudden large demand causes a dip in pressure till the regulator/pump catchup.
Make sure the filter is fresh and quality, may sound silly but the fuel filter is often neglected.
Old 08-07-2006, 05:34 AM
Louvit's Avatar
off topic a bit but where does the saftey switch go. I have one just dont know how to install it. I have a wet kit...
Old 08-07-2006, 05:38 AM
Honda Hunter's Avatar
Why would timing need to be pulled as much with 110?
Quick Reply: 150 shot on stock fuel pump?
