LT1 guys with a/c gauges!!!
I want it in the a/v vent, but everytime I try it i cant get it through the little tunnel thats there. Should I drill a whole or something because I cant think of a thing? Also, im thinking about lacing it into my ignition fuse instead of my dimmer switch.. Wouldnt that work? Thanks
I pulled the bezel for the cluster of the dash you can then see the foam seal between the duct and your dash from where the bezel was I just poked a screw driver threw the foam and ran the wires out the small hole.
