price check on cam job!
Old 08-04-2006, 03:28 AM
Cchris1109's Avatar
Default price check on cam job!
shop wants 1400:
Custom Grind Cam *comp cam* from what i heard they said 232/230
Comp Cam Rockers
Stronger Pushrods
Stronger Valvesprings
New Timing Chain
Custom Tune
They will also add in a 2500 stall installed for 400
so 1800 total?
They claim ill be able to see 360-380 whp
Old 08-04-2006, 03:48 AM
Armyman2445's Avatar
360-380rwhp I hope your car is modded already. If not there is no way a stock LT1 with just a cam will put down that much power.
Old 08-04-2006, 04:11 AM
harvickgm's Avatar
yea.... maybe 330-340.... but for the amount of work the price isnt bad.... i still say save yourself the money and do it yourself...
Old 08-04-2006, 05:45 AM
96capricemgr's Avatar
Don't give a cam that big a crappy 12" stall, at least not if you want to go fast and have the tranny last.
Old 08-04-2006, 07:13 AM
jimbob's Avatar
Originally Posted by Cchris1109
shop wants 1400:
Comp Cam Rockers
Stronger Pushrods
New Timing Chain
Custom Tune
so 1800 total?
Hey I know, have them put in writing that the work is free if it doesn't make the horse power...My guess you'll have a free cam job ....I wish you could put in a cam in a AUTO car with "NO" supporting mods and make 360-380. Hell, from 230-240 stock RWHP that is one mean cam Maybe they mean flywheel horse power!!!!!
Oh yeah, that seems like a decent price for a tune and cam job (just blank out there horse power claim)...In our neck of the woods 1100 would be good...depends on area...
Old 08-04-2006, 09:27 AM
TurboZ28's Avatar
Seems about right price wise. A little optimistic about the power estimate though.
Old 08-04-2006, 11:50 AM
RealQuick's Avatar
Stall seems low...especially for a cam with that duration.
FYI, even with supporting mods, a big cammed stock headed auto will only put down 330rwhp or so...
Old 08-04-2006, 11:52 AM
infinitebird's Avatar
I think 1800 is a little high for that.
Old 08-04-2006, 02:06 PM
Cchris1109's Avatar
i have full bolt ons
including 52mm tb, 32lb injectors, long tubes, no cats, magnaflow exhaust, CAI, ect.
Old 08-04-2006, 02:45 PM
imnotplutonium's Avatar
how would that 12 inch with that cam affect the tranny? this opposed to a 9 inch? er i think that is the aftermarket size
also cCris1109 why did you go with the bigger injectors? spray?
Old 08-04-2006, 03:55 PM
Cchris1109's Avatar
was debating on nitrous or heads/cam
i decided heads/cam so i bought the injectors...
Old 08-04-2006, 10:45 PM
The higher stall 12" converters are not as efficient and do not offer the torque multiplication of the good 9.5" units. The lack of efficiency causes heat and they weight is more abuse than the tranny needs. Talk to the truely sucessful 4L60E builders and you will be told over and over again go with the 9.5" they are easier on the tranny.
Also talking a 20lbs easily rotating weight savings which is alone worth it.
Old 08-05-2006, 02:55 AM
Cchris1109's Avatar
im doing the cam myself with help of friends, thanks guys
Old 08-05-2006, 07:53 AM
Ari G's Avatar
www.lazercams.com Great Cams oly about 300$ for custom Cam,40 for pushrods ,V.springs 80-180$
ect...
Old 08-08-2006, 10:16 AM
TurboZ28's Avatar
Thats the best way to do it.
Quick Reply: price check on cam job!
