Who makes the best aftermarket oil pan for the LT1?
Old 08-06-2006, 05:06 PM
Built LT1's Avatar
Default Who makes the best aftermarket oil pan for the LT1?
My second stroker motor is almost done and I am having an aftermarket oil pan installed for oil control. I have heard from a knowledgable freind who did research that Moroso's is the best and the Canton's leak. My engine builder swears by the Canton pan and insist that it offers the best oil control for high performance.
What do you guys think?
Old 08-06-2006, 05:48 PM
Honda Hunter's Avatar
I heard the same thing about Moroso being best and Canton leaks. For my Camaro setup I went with a Moroso. That same pan wont fit in a C4 so I bought a used Canton. So next week we shall see how it fits etc.
Old 08-06-2006, 05:55 PM
Ls1Bait's Avatar
I have a canton 6-quart and it doesent leak That has to do with the install of it. I run a Melling High Volume pump and a canton pick-up that bolts to the oil pump so theres no risk of it comming off
Old 08-06-2006, 05:58 PM
slagger's Avatar
I just bought my canton about 3months ago and not one leak. :-)
Old 08-06-2006, 06:00 PM
96lt1m6's Avatar
canton hands down
Old 08-06-2006, 06:15 PM
dhdenney's Avatar
My Canton leaks, lol. Would have bought a Moroso had they been available at the time.
Old 08-06-2006, 06:22 PM
9-Second Club
Ed Wright's Avatar
I have had 2 Cantons, on mine (hard landing got the first one) one. This one leaks, first one did not. Had nothing to do wiht installation, it's a pin hole in a weld. If you ask around more, you will find the leaky welds are not all that uncommon. I can name a couple others right now. Mine showed zero power increase (There is power in a GOOD oil pan) and looks more like a road race pan inside than a drag race pan. Can't knock it too much, should be improved oil control over a stocker.
I have ownned and sold a few pans over the years, and know what they both look like. I'm searching for something better right now. I need to talk to ProPan, where my fabricated valve covers came. Had a car in last week with a set from another place, no comparrison. They do more actual race car stuff, so no one piece rear main seal stuff on the shelf. Donavan, Dart, etc, race blocks. Probably have to take an LT1 short block up there, along with my cross member clearance measurements for them to build it.
I would fill the pan with water or solvent before installing it, and check along the welds for leaks. I should have.
Old 08-06-2006, 06:45 PM
94strokedz's Avatar
Canton on car for 2 years, no leaks.
Old 08-06-2006, 06:57 PM
96capricemgr's Avatar
One of the b-body guys has Stef's making a b-body LT1 pan that looks really nice, Ed should know the guy. I will not claim they are best but they are working with him to get stroker notching right and even oil level sender bungs, really going to great lengths to get things right.
Old 08-06-2006, 07:29 PM
dhdenney's Avatar
I would say that will end up being a nice pan. We really need some more off the shelf options for the LT1. Things like intakes and oil pans are virtually non-existent.
Old 08-06-2006, 08:22 PM
9-Second Club
Ed Wright's Avatar
Your lucky you didn't get a leaker.
Old 08-06-2006, 08:37 PM
94strokedz's Avatar
Thats what I've been hearin.
Old 08-06-2006, 09:14 PM
96blkform's Avatar
Milodon 30909 on mine, no leaks at all and it holds up to 7 quarts. I am running a Meilling HV pump also along with the milodon pickup.
Old 08-06-2006, 09:57 PM
T/A KID's Avatar
Milidon Here with pickup and pump. Yet to install but does not leak when I tested it.
Old 08-06-2006, 09:59 PM
Built LT1's Avatar
[QUOTE=Ed Wright] Mine showed zero power increase (There is power in a GOOD oil pan) and looks more like a road race pan inside than a drag race pan. Can't knock it too much, should be improved oil control over a stocker. QUOTE]
Well this isn't the news I expected, I thought the whole point of getting an aftermarket pan is because it reduced windage and INCREASED horsepower! In addition, I thought the primary reason for going with a Canton despite their leaky reputation is because they offer more horsepower! Why are we getting pans again?
Old 08-06-2006, 11:03 PM
1989GTA's Avatar
If you get a seven quart oil pan you only need to put 5 quarts in it. Need to keep the oil away from the rotating assembly.
Old 08-07-2006, 01:24 AM
SRZ
SRZ's Avatar
I run a Stef's custom pan. B-body pan that's been clearanced for a F-body as the notch won't allow the pan to sit properly due to the rack and pinion. Pan is trick as they come. I'll get pics up tomorrow or later today possibly as I just got it back from Jake @ Stef's last wk because of the above issue.
Old 08-07-2006, 10:05 AM
matt94z's Avatar
Miloden pan on my new motor. Not in car yet, but it looks awesome.
Old 08-07-2006, 11:04 AM
dhdenney's Avatar
If the pan is deep enough for 7 qts, then the crank won't be hitting the oil anyway.
Old 08-07-2006, 12:51 PM
Built LT1's Avatar
Originally Posted by 96lt1m6
canton hands down
Great!...now, can you tell us why?
Quick Reply: Who makes the best aftermarket oil pan for the LT1?
