start up problem???? help!!!
when i go to start my 97 trans am i turn the key and nothing happens except a click(like a dead battery). i turn the key off and turn it again... it usually does this 3-4 times then will start like normal... so i know the battery is fine. what is causing this to happen(faulty ignition???)...
thanks
thanks
Originally Posted by transam5.7lt1
How would it be a bad starter if it does start???? Try your ignition switch, not the cylinder. SECURITY light on?
Yea i had the same problem for a while till i figured out what it was. It was the starter just one day went into the garage got in the car and nothing. Replaced the starter good as new. Get the LT4 mini starter save some weight and it's a neat lil peice.
Jason
Jason
Jason
Jason
rule no.1 when working on aything, K.I.S.S. method, ( Keep It Simple Stupid ) i know i have forgott that and deserved all of the headach and flack that i have got, hope that helps all future projects what ever they may be
