what kind of E.T. drop from 3.23 to 4.10??
what kind of gain in the 1/4 will i get going from stock 3.23s to an auburn posi unit with 4.10s? also ill probably borrow some slicks so im hopin for 12s?
mods in sig VVV
mods in sig VVV
awesome guys! im hopin to get my rearend back from the shop tomorrow. and hopefully put it back in tomorrow night and try to run it this friday at the local track..
Yea, like they said... if you do much highway, watch out on the 4.10s you will be crankin pretty good. My car is a daily driver, however I only drive about 5 miles a day for work and its not highway. Either way.. the gears are gonna give you a serious jump. Good luck on the 12's
I have to laugh about all the talk about high RPM's on the highway. I have a 95 Trans Am and have run 4.10's for a couple of years now. I drive this car everyday it is not broke or being upgraded. I drive 25 miles one way with the cruise set at 73 MPH and turn just under 2100 RPM. I now have a set of 4.56 that will be here on Tuesday that I will run the same way. I recently drove a newer Grand Prix and although the car was bone stock the RPM that this car was turning on the highway at the same speed was around 2200 RPM. I am sure that the auto are turning higher rpms but it can't be that bad.
ill get a 12 or 9inch later on down the road but for now ill just stick with my lil ole 10 bolt. i found a brand new set of 4.10 gears and master inastall kit on ebay for about 200 give or take and i traded my friend my xbox and all the stuff to go along with it for his auburn hd posi unit out of his old 10 bolt cause he went to a 9inch so i figured what the hell i might as well try it out.. and ill be running with DR's not slicks.. i didnt want to see the outcome of that lol
Heres what it'll look like...
Edit**** Ah crap. Mines a 6 speed, so nevermind. I reread it and it says he has an A4, so that will not help him.
4.10's in an A4 is going to bring your rpms way up there.
mods in sig VVV
mods in sig VVV
