LT1 shuts off randomly during driving, any ideas?
Old 08-18-2006, 05:10 PM
BlackMagicC5's Avatar
Default LT1 shuts off randomly during driving, any ideas?
A friend of mine has a 95 impala SS with an LT1. It randomly shuts off during driving, but always starts right back up. He replaced the fuel pump and related items which didn't help. He also mentioned that the entire car was recently detailed, including the engine. I'm thinking theres a chance something got wet or messed up. I don't know much about LT1's, anyone have any ideas on what to check or look for? We'd like to start with the fairly easy common things first, then look into more serious possibilities. Thanks for any help.
Old 08-18-2006, 05:21 PM
Honda Hunter's Avatar
Could be a high res failure but that would leave a code. I'd say check the opt harness first and scan it for codes.
Old 08-18-2006, 11:24 PM
He said there are no codes.
Old 08-18-2006, 11:41 PM
donkey mule's Avatar
Possibly opti.
Old 08-19-2006, 02:21 AM
96lt1m6's Avatar
the icm could have a short
Old 08-19-2006, 04:17 AM
With a High Res Failure the light would only pop up for a brief moment then go off but it would still be saved. Did he run a scanner yet? I'd also verify the fuel pressure using the proper methods.
Old 08-19-2006, 10:25 AM
Hot94Z28's Avatar
Could be ignition switch the one on the inside of the colum or ICM if he has not changed that or like 96lt1m6 said a short
Old 08-19-2006, 10:25 PM
Dr. Teeth's Avatar
The 96 I bought had that problem. Turned out to be the opti, he had an oil leak that soaked the opti and shorted out the optical device. Check that maybe?
Old 08-20-2006, 01:14 AM
lt1taracing's Avatar
mine did it a few weeks ago and turned out to be the computer.
Old 08-20-2006, 03:25 AM
94 F-body's Avatar
Yea I would check the electrictal side, make shure nothing is grounding out before its time or pourpose, seince there has been no codes set. For instence check the spark plugs to see if all 8 are firing and trace the system back from there.
Old 08-20-2006, 07:20 AM
Louvit's Avatar
does he have an msd box? mine did that and it was a bad msd
Old 08-20-2006, 08:25 AM
Speedy's Avatar
Same thing happened to me. Optispark was shot. Would drive and the car would stutter, sometimes just die for no reason. Then it would start like nothing was wrong. Just installed a new MSD.
Quick Reply: LT1 shuts off randomly during driving, any ideas?
