CAI options
Old 08-19-2006, 08:44 PM
Revelation Z28's Avatar
Default CAI options
im torn between the Moroso or SLP. i would like to get the SLP for niceness and no plastic box looking thing, but the metal tubing attracts heat which in turn would cancel out the cold air part. or the Moroso cai since its plastic and wont attract the heat, and its a little cheaper.
what gains would i get from either one also?
Old 08-19-2006, 08:53 PM
LS1Silverado05's Avatar
I just went through the same choice. I went Moroso. I was very pleased. I can tell a difference. I went with the Moroso for the reasons that it was cheaper and I liked that it was plastic. I dont think that on a dyno you would see much difference between either one. Im not saying that the SLP piece isnt worth the money, but Im not sure that having two pipes and two filters to clean makes it any better. Either way you should be pleased.
Old 08-19-2006, 08:54 PM
Private Message sent off topic. Thanks
Old 08-19-2006, 08:55 PM
what did you feel in the terms of the difference?
Old 08-19-2006, 08:59 PM
In Need of Cup Holders!
LukePhillips's Avatar
I have heard the SLP was pretty tough to install. Something about it being a smidge bigger than it should. But both will give you similar gains.
edit: forgot to add I went with the Moroso. It fit very well.
Old 08-19-2006, 09:01 PM
well, I had all the mods in my sig before it. The CAI was my most recent mod, so I was probably really needing the extra air. But mostly it just seems to have more responce, and when I nail it, it justs acts like its gonna suck up all the air. I mean I can even hear it when its idleing. Before the cold air, when my car barked second it was a quick chirp, now its a very very hard squeel. Im sure all the CAIs available are just as good. But bottom, line, good price. Good product.
Old 08-19-2006, 09:03 PM
Yea I heard that as well, and it scared me off a little. I can say that the Moroso fit well, and makes the best use of the area.
Old 08-19-2006, 09:14 PM
no tune nesscesary after a CAI right?
im now bent on the moroso.. now that you told me you got more 2nd gear wheelspin im yearning for more too lol
Old 08-19-2006, 09:19 PM
UA-Plumber's Avatar
I have the SLP. I love it. I thought the install was a breeze. After I put it on I could hear it sucking air when I romp on it. Plus it looks cool as well. By no means am I saying your not mechanically inclined, but for someone who isnt I could see where the install would be challenging.
Old 08-19-2006, 09:34 PM
theres 2 types of morosos, the hang down type or th regular angle around the radiatior.
im gonna get the hangdown one.
Old 08-19-2006, 09:35 PM
yea...no tune. And second is niceeeee
Old 08-19-2006, 10:21 PM
the_merv's Avatar
I couldn't see spending the money on one of them..way over priced. I designed mine, and it cost me $5 in parts, and about an hour of time.
Old 08-19-2006, 10:35 PM
UA-Plumber's Avatar
the_merv; have you ran your car in the 1/4 yet? Im goin tomorrow to run mine tomorrow. Ill let you know my times.
Old 08-19-2006, 11:27 PM
the_merv's Avatar
I haven't yet. I got almost 7's on the 1/8 mile, and it was moving, so I know it will be 12's somewhere. It will be quick, just a little LT1.
Let me know how you do..
Old 08-20-2006, 12:09 AM
$5 Gave you enough to work with that you not only have a high flow filter, but also have it located outside the engine compartment?
Old 08-20-2006, 12:28 AM
the_merv's Avatar
Bingo
I bought the car with a K&N Air Filter in it, and the $5 went to the hose clamps and a piece of extra ducting from the junk yard. The rest was done with the Dremel, and some extra parts I had laying around. Where I have it located, it takes incoming outside air only, no engine compartment at all.
Like I said, I designed my version, and it works very, very well.
Old 08-20-2006, 09:47 AM
donkey mule's Avatar
I've got a Moroso and chose it over the SLP. The slp looks better but I think IMO that the Moroso is a better design.
Old 08-20-2006, 11:28 AM
gapp94vert's Avatar
hey does anybody have a part number on tht hangdown moroso cai?
Old 08-20-2006, 12:51 PM
LTSpeed's Avatar
The SLP is a little tight around the front port on the ABS modulator, but it doesn't rub or anything. All of these CAI's are more or less equal.
Some people say the LS1 lid on an LT1 is better than a CAI, but I've yet to see any apples-to-apples data. Wedging an LS1 lid under an LT1 hood can't be easy, so I'd want to see numbers before doing something that drastic.
Old 08-20-2006, 01:00 PM
ZFan88's Avatar
All the good brands are going to give you the same effect pretty much, so just with whatever one you think looks the best
