motor locked up, 3.5gal of water in oil
motor locked up, 3.5gal of water in oil ****updated pics
New 355 with 1000miles on it
was driving under 5mph in 1st gear when a noise similar to
the sound of trying to start your car while its already running (spline/gear whine)
motor shut off and will not start back
when key is turned the balancer moves, but then returns to its origional position, the clutch pedal is fine, the tranny goes into all gears without a problem
pulled the plugs, tried to manually turn motor...still seized....
drained the oil and 3.5gal of oil and coolant came out.
whats the next step???pull the heads and see whats salvagable???
That's MISTER MODERATOR
Where do we begin??
Who built the motor?
Wrong head gaskets?
Improperly decked block or head?
Old or improperly bolted/torqued head bolts?
No sealant goop on the head bolt threads?
Are the heads ported into the coolant passages?
Improperly prepped block?
Cracked block?
All these questions point to an improperly built motor.
Pull the heads. If you're very lucky, the problem is with the heads and if you didn't bend a rod, the short block can be reused.
Better yet, pull the motor and give it back to the shop that built it. They need to see what they did wrong and stand behind their work. Surely there's a warranty.
Good luck!
Wrong head gaskets?
Cracked block?
Good luck!
Originally Posted by TurboZ28
No bueno. Is there any way that this could be caused by something else besides a screw up by the builder?
Also wouldn't it hydrolock before 1000 miles?
Well from the images. It doesn't look good unfortunately. You will also want to visually check the rod to make sure it is not damaged. Have you determined what caused the problem. Did the valve drop or did a coolant leak start the damage?
Well I made a post on cz28 about a month ago about disappearing coolant. Pulled the engine out (actually a bunch of badass friends did since im at school right now and the car is 100 miles away) and the oil drained consist of about a third of water/coolant. This is on a 95 z28 with 116000 miles. Trying to figure out the most cost efficient way of getting it running again. Im pretty sure since there are so many miles on it and not knowing how many miles of those were with water in the oil that the bottom end is toast. Ive seen a few short blocks on here for pretty cheap..............What would you do...Funds are very limited
Originally Posted by Old Geezer
coolant in the oil, the bearings ARE TOAST. Especially, if the coolant was antifreeze..
Was the reason found why you had all of that coolant in the Engine all over the place?
did coolant actually run through it? or did it just come out of the head when the vavle was broken... if the engine stopped when that happend then no coolant was run though the bearings...
