oil pressure gauge fluctuation
ever since i got my car my oil pressure gauge has been fluctuating a little between changes in throttle pressure. is this normal or is something wrong with the gauge, cuz the car performs fine. thanks.
youre gonna hear someone "knocking" at your door soon.
mine is: cold start idle- 50-60psi, hot idle- 20-22psi, driving hot- 40psi
Originally Posted by UA-Plumber
Mine Idles at 10, can we say boom boom soon?
Originally Posted by Bawls
Mine has been idling warm around 10-12psi, cruising around 40psi, and WOT around 55-60psi for about 30,000 miles now.
MIne bounces everywherea taidel though... i need a new sending unit (that is why i got my autometer gauge...)
The stock gauge is pretty inaccurate as well, most of these guys with low pressures probably aren't really running that (or the higher pressures either probably). If you suspect your pressure is low first thing I'd do is get a mechanical gauge and verify the actual pressure.
My dash gauge reads around 18 psi at a full warm idle, and hits about 30 at cruising rpms and 38-40 at full throttle, all at engine fully warmed temperatures. According to my mechanical gauge I've hooked up to verify readings, my dash gauge is about 8-10 psi low across the board.
GM's specs are actually really low, min idle of 6, like 18 at 2000 rpms and 24 at 4000 or something like that if memory serves, I'd be more than a little worried about my engine if it only held 6 psi at idle though...
