Ported Stockers Vs. Entry Level Aftermarket Heads
Old 08-29-2006, 03:38 PM
LS1Silverado05's Avatar
Default Ported Stockers Vs. Entry Level Aftermarket Heads
I was just pondering this question. Would a person be better off buying a set of..let say for arguement a set of the 1,359.95 Trickflow heads and picking a cam. Or doing an extensive porting job/cam package like an LE2 or LE3? I think the cost would fall in close to the same. I was just curious. Bottom line I guess witch should put down more power?
Old 08-29-2006, 03:59 PM
Honda Hunter's Avatar
Off the top I would say the LE2's would make more power because you lose c/r with the TF's on stock N/A cars.
Old 08-29-2006, 04:48 PM
vanilla89's Avatar
the trick flow's arnt much better then stock till u port them
Old 08-29-2006, 05:01 PM
slowmofo's Avatar
trick flows are more for boosted or stroker apps... Go with stock castings
Old 08-29-2006, 05:21 PM
IllusionalTA's Avatar
+1 for LE Package's..
Old 08-29-2006, 05:30 PM
Hark_Z's Avatar
port da stockers
Old 08-29-2006, 11:29 PM
I was pretty sure thats what you guys would say. Thanks
Old 08-29-2006, 11:34 PM
96lt1m6's Avatar
you will have the purchase price for thr TFS heads plus the price of porting etc.that comes to 2600.00
gm lt1 heads avg. used price 2-300.00,full portwork,complete valvetrain for 1500.00 its your choice from there
Old 08-30-2006, 06:39 AM
curlyws6's Avatar
I've got factory castings that were re-valved, ported, and polished and am very happy with the numbers. I probably could have gone a little larger on the valves but went with the machinist recommendations. The numbers below are with a 224/236-112LSA cam on the factory re-worked heads (we did find a problem with the valvetrain which has been corrected so I'm hoping the numbers will be better when I go for my re-tune).
Old 08-30-2006, 09:17 AM
streetrod93's Avatar
ship them off to either LE or AI....those are two of the best lt1 head porters that frequent these sites...you won't be dissapointed...not ot mention the package includes a cam, so you save another couple hundred buck right there.
Old 09-01-2006, 08:30 AM
MrCadillac's Avatar
I agree. Aftermarket heads have not really outshined the stocks, atleast in as-cast form.
Old 09-01-2006, 06:50 PM
96capricemgr's Avatar
Many very highly respected LT1 headshops prefer 2.0/1.56 valves over the old 2.02/1.6 valves most newbies believe they need.
I run a similar duration cam and using my 12.5 at 107mph run from back in june and my 4250 raceweight comes out to 406rwhp according to every online MPH/weight+HP calculator I could find. AI gets my vote, this was on a mailorder tune too not a dyno tune and through full ehaust etc. it is a daily driver that gets some time at the track not the other way around.
Old 09-02-2006, 02:52 AM
hvyss's Avatar
I agree . Port the stockers. Look at my sig with LE2 heads and a baby CC503 in a 4400LB boat.
HVY SS
Quick Reply: Ported Stockers Vs. Entry Level Aftermarket Heads
