Parts for my cam?
Parts for my cam?
What Kind of valve springs, Rocker arms, and lifters should I get for my COMP CAMS LT1/LT4 XTREME ENERGY 276 CAMSHAFT #07-503-8? I bought it a couple days ago. My mods are ram air, 4" exhuast with no muffler and no cat, accel ignition system, 3.73 gears, Lt's, and a 52mm TB.
I put the 503 cam in my 96 late this winter with lt4 springs, stock stamped rockers, stock pushrods, and comp cams lifters which if i did it again i would use a new set of gm lifters and not the comp cams.
ive heard of problems with the lt4 springs binding in high lift situations. as for lifters and rockers unless you are going for a race setup look in summit and get part # SUM-HT214 lifters and summit part # SUM-G6936-16. both of these products are summit private brand but ive had great success with both. the lifters are oe style roller lifters and are perfect for the application. as for the rockers they a nice light set of aluminum rockers that are well made and heavy duty and have no problems clearing the valve covers or the valve cover bolts
