Need LT1 Head to Block help!
While doing a head swap on a 95 LT1 we ran into a problem... The car had a blown head gasket in the forward area of the passanger side head. The bolt came out clean but was very tough to get out. When putting the new heads back on the block, the new ARP bolt would only thread half way and become very tight. We took the head back off and began to tap the engine block. The tap worked fine and the ARP bolt threaded just like it should. but when we put the Head back onto the block, the ARP bolt would thread nicely untill it was flush with the head any any more wrenching and the bolt would simply spin free without any resistance. When we unscrewed the ARP bolt it took out some metal shards with it.
What do we do now? We were in the process of tourqing all the bolts down in order and this is #14 in the process.
Do we helicoil it? Can we still do it with the head on the car?
We need help as quick as possible!
**** i would say Helicoil but it may or may not work... call up a engine machine shop and ask them if they sell a helicoil that works... a normal helicoil will not hold up beyond 30 ft lbs. in my expierience...sorry for the lack of info but its a start.
