Which Cam???
Old 09-13-2006, 08:05 PM
Matts94Z28's Avatar
Default CC306 or Comp 230/236?
CC306 Or the Comp "Extreme" 230/236?
I already have the 306 but ive been thinking of selling it and getting the 230/236. Im open to any suggestions.
Ive heard that they both put down similar numbers. Keep in mind this will be a daily driver that will see some track time but not much. The motor will probably see ported heads a few months after the cam. almost 45k on the motor mods are in sig. thanks in advance guys
Old 09-14-2006, 07:41 AM
Matts94Z28's Avatar
anyone?
Old 09-14-2006, 09:10 AM
MrCadillac's Avatar
so your going with less exhuast duration but the same intake duration? are the lifts, LSA, or ramps different?
Old 09-14-2006, 04:57 PM
Matts94Z28's Avatar
I havent realy looked into it that much. i will stick with the 112lsa if i trade. i just know the cam makes as much power as the 306...but it might be a little more streetable.
Old 09-14-2006, 05:47 PM
91Z28's Avatar
THere are 2 "Extreme" 230/236 cams. The Xtreme Energy is 230/236 .510/.520 (1.5) 110 LSA (can be cut on a 112) or the "Xtreme Fuel Injection" 230/236 .576/.571 (1.6) 113 LSA, which one are you considering?
Old 09-14-2006, 06:12 PM
TwoFast4Lv's Avatar
I tell you what. I will give you the choice of a GTP6 or a GM#847. Either one for $175 to your door and you will have a better cam then either of those and they will be easier on your valve train.
Old 09-14-2006, 07:01 PM
Matts94Z28's Avatar
Im guessing its the Xtreme Fuel Injection 230/236 .576/.571 that ive been hearing about. Which one would you guys recommend? I think i would be happy with the c306, but then again if i can get more power from something similar im cool with that too. Any comparisons out there? Anyone running any of these cams? all info would be great. thanks guys!
Old 09-14-2006, 07:04 PM
Matts94Z28's Avatar
Well i dont know anything about the GTP6 and i was actually considering the 847 but i went with the 306 cause it was slightly smaller.
Before i forget im going to be running 918 springs and trick flow pushrods...if that helps anyone with my concerns.
Old 09-14-2006, 07:40 PM
91Z28's Avatar
I bought the 280XFI cam (the one mentioned above) and plan on using it with 1.65rr to get .596/.591. The lobes are bit more aggressive than the Xtreme energy ones and provide more lift with a wider LSA. The cc306 might work better with nitrous or provide more top end but I went with the 280XFI because I have a hunch it'll make at least the same amount of power with a better curve and more streetability.
Old 09-14-2006, 08:21 PM
Matts94Z28's Avatar
Hmm...where did you buy the cam from if you dont mind me asking. Dang i really dont know if i should stick with the 306 or not...decisions, decisions
Old 09-14-2006, 08:28 PM
91Z28's Avatar
I got it from summit for 245$. I think comp wants 373 or something like that.
http://store.summitracing.com/partde...5&autoview=sku
In stock too, the Gen I version is always backordered for some reason. It was back when I got mine in April too.....
Old 09-14-2006, 08:34 PM
Matts94Z28's Avatar
Thanks...i will have to look into it. By the way your cars is SICK!
Old 09-14-2006, 09:04 PM
Matts94Z28's Avatar
anyone else have any ideas or opinions?
Old 09-14-2006, 10:44 PM
91Z28's Avatar
Thanks for the compliment. If you have any questions about the EXACT cam specs for the 280XFI, such as IVO or anything like that I have the cam card and would be more than happy to post up any info you might want.
Old 09-15-2006, 01:21 AM
TwoFast4Lv's Avatar
DANG! never heard of GTP? I must be getting old
Old 09-15-2006, 04:11 PM
Matts94Z28's Avatar
haha no im just 19!
Quick Reply: Which Cam???
