i dont know what to do
Old 09-14-2006, 11:17 PM
Taubr Unit's Avatar
Default i dont know what to do
so im in the market for a cam. Looking at the 306 or the 305 cams. Ill have stock heads with maby 2.02 1.60 valves but stock porting. What cam will give me the most power. Its a strip / street car so i dont care about emmisions or streetabilty, just plain power. What should i be looking at. Anyone got real word numbers and 1/4 mile times with cam only lt1's with bolt-ons? My mods are in my sig..
Old 09-14-2006, 11:32 PM
fordeater's Avatar
my cam only lt1 with bolt ons and a crappy nitto d/r was hittin high 12s and ur car should be better than that with either of those cams i would belive.
Old 09-15-2006, 01:04 AM
Taubr Unit's Avatar
you got a lt4 hot cam right? thats what i heard through the grape vine. Im deff. looking for a better cam then that.
Old 09-15-2006, 06:36 AM
MrCadillac's Avatar
bigger valves with stock porting... uh huh... good luck with that.
Old 09-15-2006, 07:38 AM
fordeater's Avatar
ya its an ok cam but i shoulda did things differently.
Old 09-15-2006, 12:05 PM
redneck01's Avatar
try a 503 cam for great streetability and power..or if you wana go faster get an 847. the 503 is a sweet cam and has an awesome lope to it. it great on stock heads too.
Old 09-15-2006, 12:29 PM
96capricemgr's Avatar
You would have been FAR FAR better off to port the heads and keep the stock valves not even just stock size the actual stock valves.
I would say skip those off the shelf grinds especially since you are not talking emmisions. Basically all the off the shelf stuff is compromised for drivability and emmissions based on the fact people will pick a too large cam.
Old 09-15-2006, 12:45 PM
96lt1m6's Avatar
you really should contact bret bauer about the cam for your set up.
if you have no worries of the dreaded emissions factor, you should be looking at cams with a 110*lobe sep,you may even wish to look at www.eportworks.com his combos really get down.
Old 09-15-2006, 12:52 PM
Taubr Unit's Avatar
yea, no emissions on my car at all and gonna be a strip car. I dont got he thousands for a LE3 package or anyting. But i would like to put in a cam. And while im at it, my local machine shop can 3 angle my stock valves and mill it a little for $250 pr. So not bad at all. So ill do the head job and a cam.
Do you guys got any numbers i can call and talk about getting a cam ground?
Old 09-15-2006, 02:43 PM
Bad Dad's Avatar
I've got a 503 for sale.
224/230 .502/.510 with 1.5's 112 PN 07-503-8
11.95 @117 stock heads in a 383. Great street manners and TQ. I always
thought it was a little small for a 383 but would be perfect in a 350.
Used 3k miles 125.00 shipped.
Old 09-15-2006, 02:59 PM
96lt1m6's Avatar
sometimes less is more!sweet price on that cam as well
Old 09-15-2006, 06:54 PM
GIZMO's Avatar
Why??
Old 09-18-2006, 10:29 AM
MrCadillac's Avatar
Originally Posted by GIZMO
Why??
cuz they work, and there's no sence in fixing it if it ain't broke.
Also, the stock valve job is likey better than a typical 3 angle one.
Old 09-18-2006, 02:32 PM
Bad Dad's Avatar
Likely NOT
Old 09-19-2006, 11:18 AM
MrCadillac's Avatar
Originally Posted by Bad Dad
Likely NOT
you have information to prove otherwise? now if we are talking a 5 angle job, thats a different story.
Old 09-19-2006, 11:29 AM
Bad Dad's Avatar
Yes I do....do some research.
Old 09-19-2006, 04:25 PM
GIZMO's Avatar
Sorry, but you guys are way off base on this one.
Old 09-22-2006, 12:20 PM
MrCadillac's Avatar
yea? would you be so kind as to fill me in, or atleast point me in the correct direction. I enjoy learning. ya know, so I'm less retarded.
Old 09-22-2006, 12:41 PM
ToxicTA's Avatar
As mentioned above if your not going to port the heads then I wouldn't change the valves. This is just an impersonation. "You wouldn't hook a Fire hose up to your outside faucet to wash your car would you?" Ok
Most of the current machine shops do 3 angle jobs now and just call it a valve job because that would be the standard.
And in one day it went from a Street/Strip car to a Strip car which is it?
Old 09-22-2006, 10:52 PM
Taubr Unit's Avatar
What does it matter what it is. Hell, i would drive John Forces funny car on the street!! Im racing the car weather it be on the street or the strip. Stop tryin to nit pick my thread and answer the question, dont analyze.
Quick Reply: i dont know what to do
