motor mounts
you plan on taking the motor out and installing them??? If so it's not hard provided you have the motor up enough to install em....
I put them on my LT1 and it was pretty easy but I had the motor on a stand... If you plan on doing it in the car good luck...
It roughens up the ride inside the car due to vibration quite a bit but you'll pick up a little bit of power from the motor not torquing over on the rubber mounts....
