Lt1 Turbo Cams ---
Lt1 Turbo Cams ---
I'm looking for some cam recommendations for the lt1 turbo set-up. I want something a little little more aggressive sounding then my lt4 hot cam. Is anyone here running a nice sounding turbo cam with there set-up. If so what are the specs and how much power are you making with it.
look around for a custom grind..... it all depends on other internal mods u have heads so one so forth... if you're on stock heads try to find something with a longer exhaust duration on a wider lobe seperation then 112 try 114 or 115....
