Lt1 Opti Delete?
Old 09-22-2006, 06:06 PM
MUSTANGBRKR02's Avatar
Default Lt1 Opti Delete?
you guys ever heard of the mod to upgrade your car so you dont have the opti-spark set up? I saw it on one of these boards. Is it any good? worth the money? does anyone know what i am talking about?
Old 09-22-2006, 06:17 PM
Honda Hunter's Avatar
You saw a Delteq or LTCC. You cannot delete the optical part of the opti. Mabey one day we will have a opti delete but I dont see it happening.
Old 09-22-2006, 06:47 PM
Vettetech81's Avatar
You need to have the optical part have a signal for the PCM...
-=Rick
Old 09-22-2006, 07:15 PM
-=Rick
Re-read what I typed. I said that
Old 09-22-2006, 07:17 PM
hashtagBMW
Speed Density's Avatar
Single plane - distrubutor hole - crank trigger - Big stuff 3!
Done.
Tony.
Old 09-22-2006, 07:27 PM
[QUOTE=Honda Hunter]You saw a Delteq or LTCC. You cannot delete the optical part of the opti. Mabey one day we will have a opti delete but I dont see it happening.[/QUOTE
is this worth the money?
Old 09-22-2006, 07:34 PM
Yep, sorry I was just thinking about it and wrote the basic reply.. I was thinking about what if there is another type of trigger for a stand alone ignition system... N/M sorry burned out from a long day...
-=Rick
Old 09-22-2006, 08:10 PM
[QUOTE=MUSTANGBRKR02]
It depends. It's another option. It's worked ok for some and not for others. I "myself" wouldnt go that route. I went with a Dynaspark because it's proven.
Old 09-23-2006, 11:29 PM
Camaro Bird 1987's Avatar
jsut keep with the opti... it is not half as bad as people make it out to be.
Old 09-24-2006, 01:37 AM
whyte95ZRida's Avatar
I got the msd and love it. Its make room for timing adjustments and has a good design. I never messed with the timing but the distributor all together works damn well.
Quick Reply: Lt1 Opti Delete?
