Problems Draining Block
Basically both plugs are frozen in the block to drain the coolant. I was gonna just pull the drivers side bc I didnt want to risk breaking the knock sensor. Well the drivers side is completely frozen! I have tried my ratchet and soaking it with penetrating oil and then took my 3/8in impact (280ft/lbs reverse) to it and its not budging. I'm afraid if I do get it to come out it might not go back in, so now what to do? Pull the heads and clean the cylinders out? Jack the car from the rear and see if the coolant will flow out the front where the WP was? Im done working on the car today but the heads are the next thing to come off. Any ideas appreciated.
H/C in progress...
H/C in progress...
