how to replace the opti
i was wondering how you go about this, what do i have to remove to get to the opti, and does anyone have some tips to make this easier, so far i have removed the discounted the battery, took out the air intake, fans, and drilled the coolant, is the water pump next? or do i have to remove the dampener? or both? im just going to be replacing the optis cap and rotor,
thanks
thanks
yea... i did mine without pulling the radiator... just take the fans and shroud out... i had to pull my PS pulley so i could get the the WP bolt on the far left.. i got it out but couldnt get good contact on it going back in... and i didnt want to beat up the pulley so i just got it out of the way...
I usually just pull the radiator, fans, and condensor (no longer in my car) out all together since they are somewhat attached. I usually get the fans hung on a hose or something so I just pull it all out.
i almost have the pump out, but im hung up, seems the water pump goes behinde the drivers side braket, i have to pull that to? is it just the 2 bolts like in the 2nd pic i attached?
also the 3 bolts on the pully do i need to unbolt thos or just unbolt the the bolt that bolts to the crank?
i didnt have to pull the PS pully,
