Defog sw won't stay on long enough??
Old 10-01-2006, 08:58 PM
alconk's Avatar
Default Defog sw won't stay on long enough??
Now that it's getting colder I've had to use my defog switch but it only stays on for less than a minute. I had a extra switch and it also does the same thing. My other vehicles the sw. stays on until the glass has completely cleared so I know something is wrong. Any ideas??
Old 10-01-2006, 10:19 PM
Briand069's Avatar
I had the same problem and did the same thing but it ended up being the circuit breaker. I replaced it and it worked fine for awhile but started acting up again so now I have a 30 amp fuse in its place. I have read elsewhere thats what alot of people do instead of messing with the CB. Also, when you pull the breaker out check the contacts and clean if needed.
Brian
