What temp is the stock LT1 t-stat??
180 degrees, most mechanics will tell you that is wrong though hell so will most gearheads not familiar with this engine. The different from normal cooling circuit uses a non-standard 180 degree stat stock don't let anyone convince you otherwise. It is also specific to this engine using twoplates to control flow rather than just one.
the stat is 180, fans come on at deg F 226º "OFF" at 221º and secondary fan "ON" at 235º "OFF" at 230º, i would tune the turn on and off fan temps, on the PCM they will be deg C, sometimes using a lower stat well actually make the car run hotter do to the fact that the coolant wont stay in the radiator long enough to get cooled
http://www.stewartcomponents.com/tec...ech_Tips_3.htm
go pull your stat and then get back to me
Originally Posted by Dimitriz28
I just took out my 160* the other day and replaced it with stock in order to pass emissions. (My HC levels were high) The temp does not stay the same as with the 160*
