anyone have pictures of single turbo LT1 setups?
Old 10-10-2006, 02:04 PM
indirocz28's Avatar
Default anyone have pictures of single turbo LT1 setups?
I am looking for pictures of single turbo LT1 setups in the engine bay. if anyone has any please post them.
Thanks
Old 10-10-2006, 02:12 PM
onebadblackz's Avatar
no offense its before the other people get assy.... search it cause thats how I found mine...
Old 10-10-2006, 04:12 PM
indirocz28's Avatar
Default Whats better- Centrifugal Supercharger or STS rear mout?
Well- i searched for a good while now- not seen any single turbo setups, but have found lots of interesting power numbers, and setups..
I've also figured out that the STS type rear mount system seems to have alot of crap to hang with it. ie- vaccum lines, oil/water lines, extra piping etc.
Are people making about the same power with Centrifugal blowers on most streetable applications on " pumpgas" ( 93ish octane)
What do ya'll think is better - as far as time for install, tuning, and price goes?
Old 10-11-2006, 01:11 PM
BeaversTA's Avatar
Im almost done putting mine together.
Attached Thumbnails anyone have pictures of single turbo LT1 setups?-photo_0034.jpg
Old 10-11-2006, 01:17 PM
indirocz28's Avatar
Nice- now how is your exhaust from the manifolds to the turbo ran? - are you using single header or exhaust from both?
Jeff
Old 10-11-2006, 07:16 PM
BeaversTA's Avatar
This kit was a custom set up made by a member on cz28.com. Its kind of a craze set up if you ask me but it works. The right side crosses over in front of the k-member and joins the driver side and goes into the turbo .96ar T4 housing into a 3.5" down pipe all the way to the back.
Old 10-11-2006, 07:28 PM
indirocz28's Avatar
Is it price efficient? Who set it up, and can it be done for less than $2500?
Old 10-11-2006, 07:34 PM
SWINGRRRR's Avatar
Well, it is a turbo.
Mine will be similar to this. The turbos getting flip-flopped.
Old 10-11-2006, 08:42 PM
indirocz28's Avatar
how are the manifolds run? can you get me pictures of them?
Old 10-11-2006, 09:45 PM
ToxicTA's Avatar
That Awsome!!!! What size turbo is that and hey how about some prices...
Old 10-11-2006, 11:49 PM
96silverram's Avatar
I hope to god that the fuel line in that pic is not going to be laying right on the turbo housing
Old 10-12-2006, 01:57 AM
BeaversTA's Avatar
The pic of my turbo Z is old. I have sense installed a gen 7 and new fuel lines so no the fuel lines are no longer on the turbo. The turbo is a small frame T88 with a .96ar T4.
The guy who built this kit is no longer building them. The kit I have is the only one like it that he made.
Old 10-12-2006, 12:51 PM
RealQuick's Avatar
Yours will be better
Old 10-12-2006, 12:54 PM
RealQuick's Avatar
And another kit I made....
Old 10-12-2006, 02:04 PM
slick1851's Avatar
How much are the kits?
Old 10-12-2006, 09:50 PM
Moderator
BizZzatch350's Avatar
Prety cool keeping the acesories, but why not switch to a tubular K and lower A arms? seem like it would free up some space to work with over the stock stamped peaces.
Old 10-13-2006, 12:45 AM
PunishedU's Avatar
BeaversTA:
That is one clean looking setup, i want to know more about it. Also, are you planning on relocating those fuel lines? I would be worried about them sitting on top of the turbo like that.
Old 10-13-2006, 07:50 AM
RealQuick's Avatar
I assume this was for me. I have tubular stuff on my personal car and just use the stock stuff as mockup. This way the kit will fit the worst case scenerio (stock stuff). You are right though, the tubular stuff gives a shitload of clearance.
Jon
Old 10-13-2006, 03:03 PM
BeaversTA's Avatar
The fuel lines have been relocated with 6an lines. The set up is realy simple custom headers that tie into each other and conect to the turbo at the front left of the eng. There are a few things about it I would like to change but for now it will do.
Old 10-13-2006, 05:11 PM
trouse40's Avatar
what bov are you running? where did you get your ic piping?
Quick Reply: anyone have pictures of single turbo LT1 setups?
