What Pistons for Eagle 383 Stroker Kit??? - LS1TECH
Thread Tools Search this Thread
Old 10-15-2006, 12:07 PM   #1
Default What Pistons for Eagle 383 Stroker Kit???
What Pistons should i pick for my Eagle 383 Stroker Kit i am purchasing for my street car prodject? I will bw running So. Cal. 91 octane swill. My choises from eagle are as listed on there order sheet below. I will be using 62cc chamber Trick Flow Heads which will get me at apr. 11.4 to 1 which may be a little to much for the 91 octane. My other choice is to go with the KB dished pictons and mill the heads down to the compression i require.Anybody have any experience with this???.........Thanks Gman
Eagle ESP Cast/Steel 3.750" Stroke Crankshaft (Internal Balance) 1 piece rear seal part # 10352375057i
5.7" 5140 steel SIR (Full float bushed) rods with ARP bolts (SIR5700BBLW), these rods are clearanced for up to a 600 lift cam!
Keith BLACK KB135 DISH PISTONS .030, 040, .060 pistons 10.4:1 comp w/58cc head, or 9.8:1 with a 64 cc head, 8.7:1 with a 76cc head. (Compression also dependent on your deck height, advertised compression is at ZERO deck) If your deck hight is higher your compression will be slightly lower.
Keith BLACK KB134 FLAT TOP PISTONS .030, 040, .060 pistons 11.8:1 comp w/58cc head, or 11:1 with a 64cc head.
gman66 is offline   Reply With Quote
Old 10-15-2006, 12:47 PM   #2
streetwarrior96's Avatar
JE/SRP Flat tops
You should get the forged steel crank, Eagle, Callies, Lunati
streetwarrior96 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Help dynamic compression ratio lq4 KLRS10 Generation III Internal Engine 5 03-29-2012 02:34 PM
NEW!FORGED KB-718-030 383 STROKER PISTONS Keith Black/Icon +4.9cc vscott71 Parts Classifieds 1 04-22-2011 11:00 AM
how much power will this combo make? goes12s Small Block & Big Block Chevy Specific 3 10-12-2010 06:09 PM
compression ratio question joshh123 LT1-LT4 Modifications 21 03-02-2008 09:31 PM
New heart for the formula 9formula4 LT1-LT4 Modifications 4 05-07-2006 12:58 PM
Tags
10352375057i, 383, 981, black, cc, eagle, experience, keith, kit, lt1, lt4, piston, pistons, sbc, stroker, strokers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
