How much horsepower can you make with the stock Throttle Body LT1
Old 11-04-2006, 01:01 AM
ZEX-Z's Avatar
Default How much horsepower can you make with the stock Throttle Body LT1
Any ideas or answers?
Old 11-04-2006, 03:49 AM
jdhommert's Avatar
As much nitrous that you can spray through it.
Old 11-04-2006, 03:55 AM
ZEX-Z's Avatar
I already now that but how much is it good for all motor? 450,400,375,350?
Old 11-04-2006, 09:06 AM
speed_demon24's Avatar
I'm sure you could make 2000hp with it. What you should be asking is what point does it become a restriction.
Old 11-04-2006, 10:05 AM
Gun5's Avatar
yep, thats the question.. i was gonna make a thread but i guess ill just chime in here... with my suncoast ram air box.. and my whole setup is my STOCKER w/ airfoil restrictive?? how much?? i est my setups doing around 400 HP
Old 11-04-2006, 12:10 PM
96capricemgr's Avatar
400fwhp is is not going to be a big restriction but will be a little bit of one, from your sig though I would say you will be at more than 400fwhp and less than 400rwhp so I do not know where you got that number. You will gain something with a larger TB but the car will be fine without it till it becomes convenient budget wise to do the TB.
Old 11-05-2006, 07:22 PM
GIZMO's Avatar
No way would 400 fwhp be even close to needing a bigger throttle body. Try 500 fwhp.
Old 11-05-2006, 07:58 PM
Like I said it wouldn't need one. At well below 400fwhp my car started pulling vacuum over 5000rpms, never did any testing on how much power that cost me though. Made too many other changes when I swapped to the 58mm TB to really compare.
You make damn good power for the list of untouched stock parts you have to run including TB right?? How much vacuum does it build???
Old 11-05-2006, 09:52 PM
blk97z28's Avatar
hum any higher than 500fwhp?
Old 11-05-2006, 09:54 PM
Revelation Z28's Avatar
just port and polish it yourself.
Old 11-06-2006, 04:02 PM
Matts94Z28's Avatar
Rwhp...
Old 11-06-2006, 07:36 PM
buffman's Avatar
you know for people who dont have access to a lot of maching equipment that's not going to be easy. A TB can be torn down fairly easy, but not many people have access to machines that can do that kind of work, not to mention you'll need to fabricate new TB blades.
I think it's been stated on a few other LT1 boards, that yes the stock TB can make big power, but there's a point that it becomes a restriction aka you start pulling more than around 2" of vacuum at WOT. what HP that happens, im not sure, but some have even said if you get to running the car over 5000rpms then with the stock Tb you're going to be seeing an intake restriction..
Old 11-06-2006, 10:11 PM
lt197formula's Avatar
Made the numbers in sig with heads/cam/bolt ons stock intake manifold and throttle body.
Old 11-06-2006, 10:58 PM
so alot of people dont have a drill and a polishing brush for it?
Old 11-07-2006, 01:32 AM
buffman's Avatar
Revelation, I dont see how you think people with simple tools are going to be able to port a stock throttle body. If you could you'd be seeing a lot more for sale..
Old 11-07-2006, 04:56 AM
He must be talking porting everything but the actual bore and butterfly sealing surfaces which would gain you little to nothing.
Old 11-07-2006, 07:24 PM
GIZMO's Avatar
That's an interresting question. I have never checked. We are planning to try some new stuff on an engine dyno this winter. I will add a vacuum guage to my list of things to monitor. You've gotten me curious!
Old 11-07-2006, 07:37 PM
hyperzone's Avatar
I did a little work on my stock throttle body. I used 'faststeel' to mold in my own airfoil piece. I used a dremel with sander rolls along with various sand paper to smooth out the front and rear just up to the blades making sure not to mess with that. used some fine grit to really smooth it and I also found, cut, and polished a piece of aluminum to make my own top plate. I'm sure there was probably no perfomance gain by all this but, it was just a rainy day bordom thing. Here's some pics:
Quick Reply: How much horsepower can you make with the stock Throttle Body LT1
