How many of you guys drive your lt1 without letting it warm up?
Old 11-15-2006, 11:31 AM
emj2006's Avatar
Default How many of you guys drive your lt1 without letting it warm up?
Like the title says, whenever its pretty darn cold outside, do you guys run your car cold without letting it warm up? I sometimes run a little late to college and have to do that sometimes.
Old 11-15-2006, 11:42 AM
Hardtop94's Avatar
my car is done for the year and put away but regardless i always let it run for 5-10 minutes before i drive it to let everything get oiled good and some heat to build up in it and i dont run it hard until its at temp
Old 11-15-2006, 12:05 PM
CodyB4C's Avatar
in the cold mornings i let it run a minute or two but during the day i just jump in and go.
Old 11-15-2006, 12:19 PM
Ironxcross's Avatar
I give a minute or two and then go, but I drive real easy on it for five minutes after that. I learned my lesson last time on my monte where I started it up cold when it was 20 degrees out and did a burnout down the street. Then I wondered why it smelled like anitfreeze, apparently I blew out the gasket on the waterpump
Old 11-15-2006, 12:33 PM
jd783's Avatar
2-5min warm up and dont take the rpms over3grand until temp is up and you should be okay
Old 11-15-2006, 12:44 PM
LS1 Eddie's Avatar
I dont drive my Camaro in cold weather, but if I must I do let it warm up. My Expedition? It could be 5 degrees out, I'll fire it up and go.
Old 11-15-2006, 01:05 PM
94z28L's Avatar
both my blazer and camaro get a short warm up when i first start them (whether its in the morning or when leaving school)
Old 11-15-2006, 02:02 PM
buffman's Avatar
I usually let my oil temps get around 180* before I even really get into it.
Old 11-15-2006, 02:05 PM
infinitebird's Avatar
Yeah, there's really no need to let it warm up as long as you don't rev it really high when it's cold.
Old 11-15-2006, 02:07 PM
Formula350's Avatar
Hop in and go weeeeee.
Old 11-15-2006, 03:49 PM
YngBird's Avatar
i always let it warm 5 min no matter what
Old 11-15-2006, 04:01 PM
SmokedOutZ28's Avatar
My car doesnt move until the coolant temp is 150 degrees. But now that it's getting colder it will be parked soon.
Old 11-15-2006, 04:52 PM
396D1SS's Avatar
get in and go dont rev high untill 160 degreese .........thats as hot as my motor ever runs
Old 11-15-2006, 05:49 PM
the_hunted's Avatar
start up sit for a few seconds and then i go. i never shift above 2k when cold. when its warm its a whole another story!
Old 11-15-2006, 05:53 PM
FAD2BLK93's Avatar
I let it warm to the first rpm drop at startup....then go
Old 11-15-2006, 07:17 PM
dhdenney's Avatar
Precisely. Once mine gets to temp, then I hammer on it. My Jetta WON'T warm up unless you drive it. It could idle for an hour in 50* weather and the needle won't move. But in both vehicles, when it's cold, I short shift it until it heats up.
Old 11-15-2006, 07:29 PM
Ryan34's Avatar
If i shiver before i get to my car i let it sit for a minute or two, but usually i just get in and go. I lay off the throttle though.
Also i guess if you count me starting the car then finding a radio station then putting my seatbelt on as waiting....then yes i wait.
Old 11-15-2006, 07:46 PM
dre2013's Avatar
i usually let mine run for at least a minute before taking off, and if not i wont take it past 2k rpm until its up to temp.
Old 11-15-2006, 07:56 PM
JoeliusZ28's Avatar
im fussy about warmups, however there have been times when I let 160 degrees (coolant) suffice as warm enough for WOT. My car is done for the year though, so its spared from all those brutal MI cold starts.
Old 11-15-2006, 08:35 PM
Snyper's Avatar
I usually let it warm up for about a minute or two...then just keep the rpms low until the temp guage starts to move.
Quick Reply: How many of you guys drive your lt1 without letting it warm up?
