Compression question
Old 12-17-2006, 10:19 AM
97LT1's Avatar
Default Compression question
Ok I just talked to lloyd elliot about my 383, and he said use a flat top piston with a -4 or -5 cc valve notches if going N/A. This
will put you in the 11.8-12.1 CR range with a .035 quench using his LE3 package.
What is the safest compression for 93 octane? Do you think I will be ok at that compression level?
Old 12-17-2006, 10:26 AM
Tony Shepherd's Avatar
You will be fine. Monitor detonation when tuning it and set the timing at the best power with safe air/fuel and zero detonation.
I ran pump gas 93 octane on my last engine with 12.5:1 compression.
Old 12-17-2006, 10:58 AM
KWIK WS6's Avatar
Old 12-17-2006, 11:30 AM
97LT1's Avatar
Cool I was a little worried, as the stock compression is thought as high. I am feeling better now.
Quick Reply: Compression question
