Help! What goes behind my intake manifold?
Looking at the engine from the back (it's on a stand) to the left of the EGR there is a U shaped dip in the manifold with a bare bit of block exposed with a threaded hole. It looks like this hole runs into the oil galley which leads me to believe maybe the oil pressure sensor goes here? But I can not find anything in my endless boxes of disassembly parts that would fit there. Anyone know? If someone has a picture of that part of the engine I can point out which hole I am speaking of
Looking at the back of the motor, the hole on the left of the EGR in the block is for the pressure sender... Kinda.
The hole gets a hex shaped elbow, then another hex elbow threads into that, finally the pressure sender gets threaded in and rests at a 90* angle to the intake-to-block sealing flange.
To the right of the EGR? Could you be more descriptive on that one?
