Are LT1 cams hollow?
Old 12-19-2006, 10:16 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Default Are LT1 cams hollow?
Are they solid center or hollow like the LS1 cam? I never thought to look, and someone has asked me and I wasn't going to pass on wrong info without actually knowing.
Help me out guys!
Old 12-19-2006, 10:21 PM
Mighty Whitey's Avatar
lt1 cams are as solid as a rock... just like any other SBC cam.
Old 12-19-2006, 10:26 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That was what I thought. I think that he found something on ebay and it was hollow. I thought that I would double check.
I guess a dead giveaway would be the drive gear on it for the distributor.
Old 12-20-2006, 09:47 PM
the_merv's Avatar
You mean the Oil Pump drive.., or the Water Pump Gear?
Old 12-20-2006, 09:49 PM
Dragframe's Avatar
he is saying that since a SBC has a distributer on it... that would give away that its not a LT1 cam
Old 12-21-2006, 12:14 AM
actually... that wouldn't mean anything. LT1 cams still have the "distributor gear" on the back of the cam like any SBC cam, although they don't have a distributor in the back, the gear is still in the block that drives the oil pump, but nothing going to a distributor.
an LT1 cam can be run in well, any year SBC... the only complicated part would be a timing set that would work with a cam button and still have to small bolt pattern for the "OE style" roller cam.
FWIW, my truck is about to receive a Comp #501 cam that came straight out of my car...
Old 12-21-2006, 08:04 AM
the_merv's Avatar
Exactly.. we put the LT4 Hot Cam in a old El Camino, it worked very well..
Old 12-21-2006, 09:56 AM
TAEnvy's Avatar
COuld you get an LT1 cam with a hollow center. Would there be any benefits to that?
Old 12-21-2006, 12:12 PM
Revelation Z28's Avatar
less rotating weight...
Old 12-21-2006, 12:43 PM
Ls1Bait's Avatar
Not as strong, I have seen a cam break in half on a 3100 pontiac v6.
The cam bearings seized, and this cam was hollow.
Old 12-21-2006, 01:27 PM
Formula350's Avatar
The LT1 cam I bought off eBay was CNC milled, not cast like every other cam I've seen. I was very surprised. So I would say it's solid, besides the fact it was heavy like every other cam
Quick Reply: Are LT1 cams hollow?
