EWP guys come in!
Old 12-26-2006, 11:31 AM
Matts94Z28's Avatar
Default EWP guys come in!
Where are yall wiring your pumps to? I should be ready to start my motor sometime tonight but one of the last things i need to do is get the EWP wired up. Any advice would be awsome!!
Old 12-26-2006, 11:41 AM
harvickgm's Avatar
i just wired mine through a relay and to a switch in the car... but you have to make sure you turn the switch on or you will overheat the motor obviously... but i wired mine that way so i could turn my fans and pump on at the track when it was off to cool the engine... some have it wired in to turn on with the key on...
at first i had mine wired to the Air Pump Fuse since it was no longer in use...
Old 12-26-2006, 11:56 AM
Matts94Z28's Avatar
Yeah i just removed my AIR also. I was wondering what i could do for a week or so to make it work until i can order a wiring kit with the LED indicator. Could i just tap into the power source for the AIR and ground it out on the block or frame? The pump has an inline fuse in it already but im sure you guys know that. I was just wondering what you guy thought of doing it that way for a temporary fix.
Old 12-26-2006, 12:04 PM
ABA383's Avatar
Mine is wired using the "Painless" wiring kit using a relay to a switched source that turns on when the key is on...
--Alan
Old 12-26-2006, 12:07 PM
Matts94Z28's Avatar
--Alan
Yeah thats what i want to order here in a few days. I just need to get this thing running for thursday an friday since i work. Hell if i order tonight it should be in by saturday at the latest.
Old 12-26-2006, 12:34 PM
Chevydomination's Avatar
Hope this helps
http://ken.lowrance.com/projects/CSI...mp/Default.htm
Old 12-26-2006, 01:20 PM
UnitZ28's Avatar
I took power from the ingnition fuse to turn on a relay that turns on the pump when the key is turned on and grounded on the engine... works great
Old 12-26-2006, 02:03 PM
Matts94Z28's Avatar
what kinda of relay and how do i use it? I dont know jack about wiring. Also how can i make this thing work for a few days without a relay?
Old 12-26-2006, 05:40 PM
I bought a relay kit that has a warning buzzer and a red and green LED light, when is pump is working the green light stays on but when the temp goes over 230 the buzzer turns on and the red LED light comes on.
Old 12-26-2006, 06:31 PM
Matts94Z28's Avatar
Where can i get that?
Old 12-26-2006, 07:05 PM
This is the guy's email try giving him a buzz Spartus@charter.net
Old 12-26-2006, 07:29 PM
Gun5's Avatar
i know there was a site for it awhile ago, chevy u got a wiring diagram or instructions i dont think they sell it anymore maybe someone else can start making one or we can just fab up our own
Old 12-26-2006, 08:30 PM
Internet Mechanic
BlackScreaminMachine's Avatar
this is the one I used, I just made my wiring. Easy.
Old 12-26-2006, 08:36 PM
Yes, I have the diagram with instruction I know a guy who builds relay's I'll see what he can do.
Old 12-26-2006, 11:29 PM
Matts94Z28's Avatar
Thanks for all the help guys!
