Tranny Mount A4?
Tranny Mount A4?
i just blew my 2nd stock TRANNY MOUNT i heard that Energy Suspension has a good one....anyone have a aftermarket tranny mount on there car? which is the best to buy. some ideas please.
There's been some discussion regarding the excessive height of the ES tranny mount. Some suspect the added height causes DS problems and increased vibrations. I've used the same ES poly mounts under three different tranny setups
You can pick up a poly energy suspensions tranny mount from any local dap for around $20. If you do go that route, just don't include the spacer that they suggest you install. It is usually the culprit for excessive vibrations with the mount.
Shoebox has info regarding the height differences:
i have a B&M tranny mount thats basically the same as the ES one. pretty much exactly the same. the stock one went out on me. i havent had a problem out of this one on my 98 T/A. i think i might take the spacer off tomorrow though.
