Need help/info asap
Need help/info asap
I developed a ticking noise last friday just before we did a 1200 mile round trip to Alabama.
I was pretty sure it was a lifter going bad, at first start-up it was noisy (hot or cold engine), but quietened down once it ran a few minutes. My problem now is, I just ripped all the intake and valve covers off, but I can't find any of the lifters that look bad?.
How do I tell which one is going bad?, I can't really afford to replace all of them.
Also, how do I disconnect the fuel lines from the fuel rails?, I finished up having to disconnect the fuel rail from the intake and then slide the intake out from under the rail, but the fuel rail is in the way and is going to be a pain when I put the intake back on.
Also, if I block off the EGR without programming it out, will the car run ok?. I have Tunercat, but this is my daily driver and I need it back on the road by the end of the weekend, I can reprogram the PCM next week.
Someone please help, I need the car back up and running quick!! Forgot to add, this is a '94 LT1 Firebird, totally stock.
Sara Lou
Sara Lou
Sara Lou
Sara Lou
