fuel pressure
fuel pressure
i ran a pressure test on my 94 lt1 and it had around 35psi with the regulator hooked up and around 45psi when unhooked.oh yeah and that was running in idle is this a little low on pressure? i thought lt1,s ran higher pressure. just wanting to know am trying to find out the mystery power loss lately. thanks Mako
Yes stock pressure is around that with the line unhooked. With the vacuum hooked it depends on how much vacuum the motor makes and idle speed, mine is around 32 psi hooked.
