oil pressure
specs as per FSM is more like 1 psi per 100rpms so basically 10psi at idle. Should be around 25 psi @ 25xx rpms, then 30 or so at higher rpms. Something like that.
BTW DO NOT TRUST any stock gauges. Put a mechanical gauge on the vehicle to verify actual oil pressure.
