Need answer about a cam.
Old 12-30-2006, 04:58 AM
khurst94z28's Avatar
Default Need answer about a cam.
I have been emailing summit racing about a new cam for my 94z. The cam they told me to go with is below. Could some one give me some info on if this is a good cam are not
Duration at 050 inch Lift: 218 int./224 exh
Intake Valve Lift with Factory Rocker Arm Ratio: 0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.503 in
Valve Lift with Factory Rocker Arm Ratio: 0.495 int./0.503 exh. lift
Lobe Separation (degrees): 112
And they also said it would work well with my stock heads.
Old 12-30-2006, 08:39 AM
94Z28Joe's Avatar
seems like a small cam
Old 12-30-2006, 08:43 AM
tbsimmons's Avatar
That sounds like the comp 502 cam.
IMHO I would not go any bigger if you plan on keeping the stock heads.
Old 12-30-2006, 09:09 AM
MEAN LT1's Avatar
Thats a good cam and there nothing wrong with it. Even though you have stock heads I would still go bigger depending on what your goals are. Hell, look at people running the GM 847 and its way bigger than the cam they selected and it makes good power.
Old 12-31-2006, 05:14 PM
gradez28's Avatar
a cc305 might be a better choice.. it works very well with stock heads and is a little bigger than what you posted.
Old 12-31-2006, 05:25 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Id be looking at a LT4 hotcam or better.
Old 12-31-2006, 08:05 PM
matt94z's Avatar
I had that cam, it is a Comp 502 cam. Overall very nice power and torque gain. Excellent drivability, and ran 12.4's@108.78. I'd recommend it over a Hotcam any day...
Old 12-31-2006, 08:22 PM
speed_demon24's Avatar
Depends what your goals are, but I would go custom if I were you. Its only $40-50 more and the cam will be exactly what you want.
Old 12-31-2006, 11:53 PM
kngkahious's Avatar
i'd go bigger my self . that is a small cam go with a lt4 or bigger. if u want to gain power and keep drivabilty stay close to an lt4.but if u want a street strip car go with a bigger camill look around for u.u might also want to port your heads and have bigger valves put in them.you'll gain about 35-45 cfm about 10 horsepower with the stock cam.but with a custom grind or a bigger cam you could see upwards of 400 + rwhp if u have headers injectors tb and a tune and it would still be streetable
Old 01-01-2007, 06:58 AM
the_merv's Avatar
I am sporting the LT4 Hot Cam, and the Cam he posted up there is bigger than the Hot Cam by a hair. I like mine to drive on the street and for the lope, it does have a good sound. I am turning down some good numbers, but there are some nice big Cams out there.
Old 01-01-2007, 01:33 PM
Z93
Z93's Avatar
I have the cc305 cam with a custom tune from Fastchip and it works great.
Quick Reply: Need answer about a cam.
