Info I found today. For all those wondering which cam and comp.tune for street LT1
Old 01-03-2007, 08:56 PM
WONCAMARO's Avatar
Default Info I found today. For all those wondering which cam and comp.tune for street LT1
Called Comp tonight. They basically said the best idea for my cam only LT1 was the 503. It has a nice lope, yet still stays within a powerband which will not require me to rev the motor to 66 or 6800 in order to get the most power out of it. Will also work with the stock heads, he recommended a 26-915-16 single coil, bee hive valve spring which is supposed to work as well as the dual coil, and some 850-16 comp roller lifters. He also told me that a guy named Tony in the Comp Fast Department reprograms pcm's to work with the cams selected (and other indicated mods). It's 1 stop shopping. Hope this will help someone.
Old 01-03-2007, 08:58 PM
12345678910's Avatar
need he give you any hp numbers with the cam
Old 01-03-2007, 09:21 PM
WONCAMARO's Avatar
Most cam manufacturers I have found do not post hp numbers. It's all in the dyno.
