I need part number for the Comp Pro Magnum 1.6's
Anyone have that part number for the Comp Pro Magnum 1.6's NSA for a lt1? Do I need then for a 7/16 or 3/8 stud?
Dont I have a 3/8 stud stock? Those are for 7/16...Im so confused Im trying to get everything I need for a CC306 install here is what I have on my list so far.. By the way, why is non self aligning better then self aligning?
CCA-1302-16 Rocker Arms, Stud Mount, Full Roller, Steel, 1.6 Ratio, Fits 3/8 in. Stud, Chevy, Small Block, Set of 16 $269.95 $269.95
CCA-26918-16 Valve Springs, Single, 1.055 in. Outside Diameter, 313 lbs./in. Rate, 1.085 in. Coil Bind Height, Set of 16 $179.95 $179.95
CCA-4705-16 Valve Spring Locators, Inside, Steel, .060 in. Thick, 1.100 in. O.D., .650 in. I.D., .660 in. Spring I.D., Set $40.69 $40.69
CCA-4808-8 Guideplates, Flat, 5/16 in. Pushrod Size, Chevy, Small Block, Set of 8 $21.88 $21.88
CCA-614-16 Valve Locks, Machined, Hardened Steel, 10 Degree, 1-Groove, 11/32 in. Valve Stem, Set of 16 $25.95 $25.95
CCA-7808-16 Pushrods, High Energy, Chromemoly, Heat Treated, 5/16 in. Diameter, 7.195 in. Length, Universal, Set of 16 $34.88 $34.88
CCA-795-16 Valve Spring Retainers, Steel, 10 Degree, 1.095 in. Outside Diameter, .640 in. Inside Diameter, Set of 16 $50.
Don't run the comp guideplates, use the GMPP guideplates. And go with 7/16 studs, its only $30 more, and when you compare them to the stock studs you'll see why.
63-07-306-8 Comp Cams "306" LT1 Camshaft, 230 / 244, .510 / .540 112 LSA $259.99 $259.99
63-1302-16 Comp Cams Pro-Magnum Non-Self-Aligning Roller Rocker Arms, 3/8" stud, 1.6 Ratio $306.99 $306.99
63-4501-16 Comp Cams "High Energy" Rocker Arm Studs, 7/16" $33.99 $33.99
20-14011051 GM Performance Parts Pushrod Guideplates (8 needed) $3.29 $26.32
63-26918-16 Comp Cams 26918 Beehive Ovate Spring, set of 16 $179.99 $179.99
63-795-16 Comp Cams 10 degree Steel Retainer for Comp 26918 valvespring. $49.95 $49.95
63-4705-16 Comp Cams Spring Locator for use with Comp 26918 valvespring $32.99 $32.99
63-613-16 Comp Cams 11/32 10 Degree Machine Steel Locks, set of 16 $24.99 $24.99
20-12370835 GM Extreme Duty Timing Set $299.00 $299.00
99-PR7200 Thunder Racing Heat Treated Chrome-Moly Pushrods, 7.200" $109.99 $109.99
Order Total: $1324.20
Thats from thunder racing.
