Timing Chain....
Old 01-04-2007, 09:12 PM
Schweet97Z's Avatar
Default Timing Chain....
Besides the GMPP timing set, what is another one that can be used with stock timing cover? I saw Lunati made one for the earlier LT-1's for like 150 bucks, and the GMPP set is 250. Remember my car is a 97. Any help is appriciated. I have a feeling im just going to have to bite the bullet and buy the GMPP set?
Old 01-04-2007, 09:29 PM
95FbFormula's Avatar
SA Gear makes 1 its about $80 bucks I don't know the quality tho. Cast iron cam gear and steel crank sprocket. Single roller chain
Old 01-05-2007, 07:22 AM
Schweet97Z's Avatar
96slow6 do you have a part number and price? also where did you get it from? thanks....anyone else?
Old 01-05-2007, 07:30 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Lunati uses GM gears, Its their chain, its really tight when you put it on. I took my motor out after 2k on her and it had decent slack....
Old 01-05-2007, 07:33 AM
Chris 96 WS6's Avatar
The Lunati piece is nice, as is the GMPP. Not sure I'd trust an "off brand"
Old 01-05-2007, 10:41 AM
leadfoot4's Avatar
Cloyes makes a replacement set...
Old 01-05-2007, 10:55 AM
Internet Mechanic
FYI for 93-94 non vented opti spark users, you need to upgrade to a vented unit, butI have seen cam sprockets made for non vented but is mad money.
Old 01-05-2007, 09:00 PM
Schweet97Z's Avatar
so does anyone have a part number and website to get this lunati chain?
Old 01-05-2007, 09:51 PM
onephatZ28's Avatar
summit racing has the lunati chain
Old 01-05-2007, 10:48 PM
Schweet97Z's Avatar
summit racing doesnt offer the lunati chain for vented opti cars, at least thats what they have told me and i cant find anything on the website. help if you can?
Old 01-05-2007, 11:10 PM
12345678910's Avatar
cloyes does make on it $80 st summit part # clo-c-3039
Old 01-06-2007, 01:47 AM
Mighty Whitey's Avatar
are you running an electric water pump?
if so, just grap a standard SBC OE roller cam timing set.
I'm running one of the cloyes street "true" roller sets on mine, has the ability to have it retarded 4*, straight up, and adv. 4*..
I believe I paid $79 dollars for mine out of jegs???
gotta watch out about some of those timing sets that will infact "fit" the motor.. but some may not have the gear on the back side of the chain sprocket to run the water pump- no big deal if you have an EWP, but would make it rather difficult to spin the stock on if you don't have the drive gear in there!
Old 01-06-2007, 02:02 AM
it came with the water pump gear right
Old 01-06-2007, 07:05 AM
the_merv's Avatar
I got the GMPP LT4 one, look around Ebay, I got it for $200.
Old 01-06-2007, 09:31 AM
96capricemgr's Avatar
With all this talk of upgrade who has actually snapped a stock set??? Just a little food for thought.
I am not saying any of these options are bad but let's consider for a moment you have someone like me REUSING a stock set with 41K on it when I put the AI package on and it is fine, then consider I am still running the what 7-8hp it takes to drive the waterpump too because I am running a stocker there too. If you are worried about the timing set and going to an electric pump anyway just think of how much load you take off the chain with the electric waterpump.
Just to make things clear too GM made stocker for the unvented and vented optis, then an LT4 and an LT4 ED set which are different so know what you are buying when comparing prices.
Old 01-06-2007, 03:29 PM
Schweet97Z's Avatar
i dont have an electric water pump, and didnt plane on going with one for awhile either. the people with the lunati set where did u get them and whats the part number?
Old 01-07-2007, 06:43 AM
the_merv's Avatar
There was a guy on here a while back, his stock Chain actually fell apart, and ended up in the Oil Pan.
Old 01-07-2007, 10:14 AM
Schweet97Z's Avatar
that lunati set is a double roller, so im going to have to get an e-waterpump right? i want a good set, since im doing the le2 heads and gm-847 cam.
Old 01-07-2007, 10:39 AM
1997bird's Avatar
Yes you will need the electric WP with that timing set. Trust me you will be happy with the electric WP decision after you get it running again.
Old 01-07-2007, 12:33 PM
Originally Posted by 96slow6
I Dont want to step on your toes. So plz dont take offence. But its not about breaking the chain. The real question is how many of you have seen a streched chain? I have. Another good question is how many of you are driving around with a streched and wore out set losing power and dont even know it? Im not sure were i got mine its been along time and i orderd parts from alot of different places. I think i got it from Doug Herbert performance. i wish i waited they also have an adjustable set now to. Here is a link for summit http://store.summitracing.com/egnsea...115+4294924746
See there is the thing everyone like to talk about slop in the chain and asume it is a huge problem. Look at results not bench racing, most of you have a very hard time distinguishing between the two.
I am not saying the stock chain is the ultimate piece or anything just that for a mild street car like most of you have it is foolish to drop $200+ on a timing set when the $60 stock set is reliable.
Merv, someone somewhere sometime has broken every last piece in this motor, a single failure does not a pattern make. I know of a handful of LT4 Extreme Duty set failures, more than I have seen on stockers actually, does not mean they are weak just means a few folks managed to snap them.
Quick Reply: Timing Chain....
