lt1 OTVC spark wires problem
Old 01-05-2007, 03:16 PM
transambandit's Avatar
Default lt1 OTVC spark wires problem
i am having trouble getting the end of the wires to click into the distributor, anyone have a solution to this?
Old 01-05-2007, 03:36 PM
travie319's Avatar
buy some factory GM wires......still have them on my car!
Old 01-05-2007, 03:45 PM
hashtagBMW
Speed Density's Avatar
Twist and Push. Mine did the same thing.
Tony.
Old 01-05-2007, 04:02 PM
factory wires will burn up on my headers, when i took my old ones off everyone of them was burned.
Old 01-05-2007, 04:15 PM
travie319's Avatar
I have pacesetter long tubes......
as long as you zip tie correctly you shouldn't have any problems.....
Old 01-05-2007, 04:16 PM
travie319's Avatar
Tony.
or as he said
Old 01-05-2007, 06:29 PM
ABA383's Avatar
I used a little bit of dielectric tune up grease in the boots and it helped to snap them in place...Which opti ends are you using? Taylors?
--Alan
Old 01-05-2007, 06:39 PM
slow_94z's Avatar
Originally Posted by 96slow6
push harder?
Probably thank you LT1.
Old 01-06-2007, 02:07 AM
ToxicFormula's Avatar
Tony.
Ditto and try pushing with the wire not with the boot cause sometimes the boot has a tendency to flex
Old 01-06-2007, 04:04 AM
yes they are taylor.
Old 01-08-2007, 12:37 AM
luckyou03's Avatar
make sure they are pulled through the boots enough to click
Old 01-08-2007, 02:06 AM
96silverram's Avatar
Definitely use a dab of Di-electric. It will snap on much easier.
