Just wasted $300 on a Opti that didnt fix my problem, now what?
So now I have a new Opti and a new coil, whats next, the PCM? I have NO SPARK!
Well it started by having hard starts, then would start and run rough and die, then would not start at all. Dead, no spark. Yes I checked the ignition fuse in the under hood fuse box and it actually was blown. I thought that was my problem, but I put a different fuse in it that was good still no spark. Im checking spark at the plug from the plug wire. How do I know if the coil or opti that I have already changed out are even good. I hate eletrical problems! Pcm? Ignition control module? Dont know what to check or where to start. But I dont like guessing and wasting money. Im on disability and make VERY little money..
Originally Posted by fergymoto
Use this diagnostic http://www.mainstreamtopics.com/foru...p?showtopic=78
Check the wire that plugs into the opti. The one on my Firebird corroded bad and the car would not spark. I cleaned it with WD-40 and a wire brush. May not be the problem but it is free to check.
