Wheel Hub Help !!!!!!
I'm having a very bad wheel hub, here are some info of what the situation is:
It's a 94 Z28 M6 . I have a C6 17" Rims with 285/50/ZR17 tires, 4:10 gears, factory steel driveshaft, factory torque arm, factory shocks/springs.
Here's what I got so far but didn't put on the car yet:
Banzai Torque Arm. Aluminum Driveshaft.
If I get a good set of lower control arms/panhard rod and subframe connectors, will that along with the torque arm eliminate my annoying weel hub? What do you guys think I should do to avoid this issue, I'm not sure what brand to buy and what else to buy, let me know what you think.
Thanks
Thanks
