Dynoed my car today
Dynoed my car today
Well I have been having a gremlin in my car since i moved to Florida to go to school so my instructor at UTI said he wanted to put it on the dyno and see if he could see anything wrong with it. The car bucks at low rpm under load and also has a stumble at wide open throttle. He said that because of the torque numbers being so erratic that my spark plug wires might be to blame because they are throwing the probes on the spark plug wires off. I also noticed that the car was running at 14.1 a/f ratio under wot so im thinking maybe my stock 140 thousand mile fuel pump cant keep up. What do you guys think. The car also ran worse with the cutout open. Maybe i am fighting two problems and not just one?
car has:
New ac delco optispark
New ac delco plugs
new ac delco o2 sensors
New autolight spark plug wires
new Coil
new ignition control modual
Egr is tuned out of the pcm and all vacum lines capped off but egr is still on intake manifold
Long tube headers
madz28 tune
cutout
new fuel filter
Cleaned maf
newer K&N filter
car has:
New ac delco plugs
new Coil
Long tube headers
madz28 tune
cutout
new fuel filter
Cleaned maf
newer K&N filter
If you are looking at your fuel pump, then you should put a guage on it and see what kind of psi it has at idle and at wot. then go from there on the pump. dont just replace it, check it first.
Ya thats what i was saying, the out of whack torque numbers are possibly from the spark plug wires messing the probe up on the dyno causing false torque numbers. When i scanned it the other day with data master i found i was getting 5-6 degrees of retarded timing due to knock. I am thinking maybe that it is running lean (14.1) a/f ratio and then it is detecting knock and then retarding timing causing these problems?
Originally Posted by Mattybz28
294hp / 922tq
Looks like your problem is someone swapped a diesel into your car when you weren't looking!?!?
I would check the fuel pressure at WOT. That'll let you know if you need a new pump. Also, check and make sure you dont have a cracked spark plug or that one of the plug tips is not loose or missing.
Originally Posted by LT1MAN
i dont see how a dyno could read 922 lbs of tq like that.
From what i understand, the dyno uses the spark signal and the speed of the drums to calculate torque. When your spark signal gets all crazy like bad plug wires because they are arcing everywhere you get ridicules torque numbers because it throws the inductive prob on the wires off (signal wise).
