LT1/LT4 Info needed...
before you start yelling "SEARCH THE FORUMS" at me, i did, and couldnt find what i was looking for. ive seen dyno numbers nearing 370rwhp for the LT1 with an LT4 conversion. the last time my car was on the dyno, i got just under 330. now, after swapping in a new PCM, its back at a shop to get a new tune. what kind of number should i expect to see?
96 Z28, M6
4.11 Strange 12-bolt
Underdrive Pulley Kit
58mm BBK Throttle Body
8.5 MSD Plug Wires
Royal Purple Engine Oil Racing-21
160* Thermostat
LT4 Intake Manifold (ported)
LT4 Heads
LT4 Hot Cam
LT4 Knock Module
LT4 Extreme Duty Timing Chain
1.6:1 Comp Gold Roller Rockers
Dual Valve Springs
Hardened Steel Push Rods
Accel 30# Injectors
Meiziere Electric Water Pump
RaceTronics 255 Fuel Pump
Stock de-screened MAF
A/C Idler Pulley with A/C delete
Moroso Cold Air Intake
Vortec Intake Elbow
MSD Ignition Coil
96 Z28, M6
8.5 MSD Plug Wires
160* Thermostat
LT4 Heads
LT4 Hot Cam
LT4 Knock Module
Dual Valve Springs
Accel 30# Injectors
Vortec Intake Elbow
MSD Ignition Coil
No way you will see 370 on stock LT4s and a HOT cam. The engine dyno no accessory dyno tune claimed numbers for it are just 425fwhp as installed in a car will be less than that and then take away drivetrain losses.
Accel injectors were absolute junk for a LONG time, recently I have heard a single report they finally got a decent supplier, good luck.
Originally Posted by SnakeOiler
So the only thing you've done, since your "just under 330" dyno run, is do a PCM swap?
If the previous PCM was already tuned, then it won't be much more.
Originally Posted by 94 Formula
Do you have headers/exhaust on there?
I made 348hp on mine, similar setup through the stock 10 bolt. I did pull 365hp with an open exhaust and no accessory belt.
if i put down about 350rwhp, i would be VERY happy.
