How do I check the MAF sensor wires?
Old 01-23-2007, 03:55 PM
Shackleford's Avatar
Default How do I check the MAF sensor wires?
How do I check to see if the PCM is good?
Old 01-23-2007, 05:35 PM
Ralls's Avatar
Backprobe your wires with a multimeter. Three wires: power (5 volts), ground, and signal wire (PCM). I forget what the PCM gets at idle, but I assume it will be low. Then get higher with more thottle. Thats how you do it, but someone should know what the readings should be.
Old 01-23-2007, 05:37 PM
The car isn't running.
Old 01-23-2007, 05:59 PM
Ralls's Avatar
Then why are you concerned about the MAF? Make it run first.
Old 01-23-2007, 06:00 PM
Someone said the car won't run if it's bad, but then someone else said it would default to speed density. I'm beginning to think the PCM might be bad.
Old 01-23-2007, 06:05 PM
buffman's Avatar
if the MAF sensor is bad, the car can be made to run SD by unplugging it.
Old 01-23-2007, 06:06 PM
Yeah, a buddy just told me that. Thanks. We'll try that tonight.
Old 01-23-2007, 09:09 PM
97LT1's Avatar
http://www.mainstreamtopics.com/foru...?showtopic=207
Quick Reply: How do I check the MAF sensor wires?
