Bought CAM was it a mistake
finally got the zz-409 have been getting diffrent things. I am hoping to get into the 12.50s but was told that the stall i have will do me no good. Cam makes peak power at 5800rpm and have a 3500 stall stock head and bottom end lts tb 3.23 gears is it possible to get those times. was told that setup that i have will not do well together. Opinions comments what should i expect
IMO I dont see anything wrong with your set up. I have the XFI 280 cam in my car it only calls for a 2500 stall but I have a 3600. I leave the line hard as heck. It didnt slow me down any. I dont think it will slow you down any either. I think you will be fine. There have been people with Hotcams and stalls get in the mid 12's.
The stall ratings that are givin for cams are always too low. With my old CC305 comp cams says that I should have had a 2000 somthing stall. I started out with a 3200, and the car would 60ft in the high 1.7 range. Then I had the converter restalled to 4000, and the car would 60ft in the high 1.5 range. Most cam only cars make there peek torque somewhere from 4000 to 4500. If you want to go as fast as possible thats what your stall needs to be also.
remeber though a really high stall isn't all that great for a daily driver. but if you dont mind it loose go for it. i got a 3000 and think i couldve even gone for a 3400 and still have been fine.
Internet Mechanic
Just in general, bear in mind that stall ratings a re subjective to many factors, such as cubic inches and weight of the car.
Just cus it says 2500, 3000, 3500, ect ect that it may not hit that number, I had a 2500-2800 stall and I would hit stall wall with easy which is mentioned to be 2800+ on 94-95 cars with 4L60e's and ODB1
thanks guys I feel much better now i was banging my head on the wall because i thought i had made a mistake. Now that i have heard other people have something like my set up
Army man what are your cam specs and what gears are you running
Foggedz what are also your specs and gears
I had a CC305 cam, full boltons, stock bottomend, stock heads, th350 with a 4000 stall, 3.73 gear, works with eather a 26 or 28 tall tire. The specs on the CC305 cam are 220/230 and .544/.544 with a 1.6 ratio rocker arm. My car went 11.70 with this setup, so you should have no problem going 12.50. Im currently puting in a larger cam, that is based off of a GM847 cam but a little different custom grind by crane.
those times are great man do you see my car doing at least an 11.90 or 12.00 . Would really love to do those times you are making. As for suspension wise what is your set up. So far what you described have almost the same. so do you see it happening with my car
For syspension I have Hals all the way around, spohn torque arm, LSA'a, panhard bar, and subframe connecters. You can check it out hear. https://ls1tech.com/forums/lt1-lt4-modifications/596981-new-cam-only-times.html
Nah, that was on motor, but its even faster on spray. I didnt get a clean spray pass when I was at the track. I should have some even better motor numbers next year along with some good nitrous passes.
The two main reasons for the good times were weight reduction, and a Th350 trans with a big stall.
