A/C Delete w/ Working Heat
I dont know if this was worth all the extra work but I did it! I removed the evaporater as outlined in the chiltons manual then cut the big black box out of the car. I had to clearance the blower motor so It would blow thru the heater corps without the A/C box in place and filled in the gaps with Fiberglass. I got this Idea from a The Merve. I fabed the A/C delete plate out of plane old sheet metal. All other A/C parts have been removed as well and the 1LE pulley is in place. I wouldnt recomend doing this with the motor in
Originally Posted by Torkman15
Thats cool, did you weigh everything for a comparison to total elimination of HVAC unit. I have a small heater that plugs into the cigarette lighter outlet just for cool fall nights so my windows dont fog up.
Very cool idea though
Wasn't metioned on this board that you need intake hole in that block off sheet for the blower motor to be able to suck in air from the engine compartment then through the heater then through the vents?
Then where does the blower get the air from to HEAT the HEATER core? I only ask so i dont run into any road blocks since i am currently working on the "ac delete w/ heat"
