stumbling
stumbling
ok maybe someone can point me in the right direction .
i put tranny ,comp, and wiring harness out of a 94 z28 in my 95 formula .
the car startes and idles fine but if you press the gas it stumbles up to about 3000 or so then it smooth out . from about 3000 to 5000 it revs smooth but it still revs slow .
the fans come on as soon as you start the car and the only way to get them to turn off is pull he relay , and the fuel guage goes up and down randimly . (way past f then down to 3/4 then back up again . to add insult to injury the car sounds like a 6 cyl .
The fans comming on right away tells you that you have tripped a trouble code. Get it scanned to see what the code is. was everything the same between the two cars? As far as gear ratio...the pcm may need to be reprogrammed.
