30lb injector adjustment
Old 01-31-2007, 03:48 PM
ssean92's Avatar
Default 30lb injector adjustment
im trying to figure out how to adjust my tune for the new 30lbs injectors i picked up, ion said i need to adjust the constant and the wot air/fuel. i am running at 50 psi can someone help me out
Old 01-31-2007, 05:00 PM
9-Second Club
Ed Wright's Avatar
Why so much fuel pressure? At 47 psi @ WOT I use 31.61 for the injector constant. I also adjust the offset table some. 31.61 or 32 should put you close enough to start tuning it.
Good luck, Ed
