Why wont my LT1 shift out of 3rd at 135mph?
Well at WOT my car would just bounce off the rev limiter at the top of 3rd. I found this out when i was racing one of my buddies. Im hoping i dont have to get a tuner to set it up. I know my LS1 shifted into OD but my LT1 wont???
That is weird. When I bought my car I could tell that my OD was slipping as the rpm's were a lot higher while cruising down the highway than they should have been for a 3.23 rearend. I noticed that mine would bounce off the rev limiter when going from 2nd to 3rd under WOT. I never ran it fast enough to try the same into OD, but I'm guessing it would have done the same. Then one day after I had romped it up through the gears I lost 3-4 completely. I had lost the clutch pack.
Originally Posted by Schweet97Z
the 4l60e does allow WOT shifts from 3-4. It sounds like the 3-4 clutch packs are shot.
have you had the car over 135 mph before? because my last 94 6speed had a governor on it and at exactly 135 it would cut the fuel out and it wouldn't go any further. it could be that the transmission is capable of shifting but the computer wont let it because it is supposed to shift right there where the governor is. jmo.
9-Second Club
Many 700R4s won't go into OD at WOT. There is a piston you can buy to fix it. I know B&M used to offer it, probably every other tranny builder does also.
Forgot the name of that thing, but it is a small piston, looks like 1 piece of aluminium. Your car may have had another tranny put in it. I believe the Z28s would go into 4th WOT from the factory, many lower perf cars won't.
Good luck, Ed
Good luck, Ed
Originally Posted by bjamick
So my car has a 700r4? I thought that it was a 4L60E? Well i guess i learned something new. Ill ask my transmission guy how to fix this so i can pull on the ricers even worse.
94+ have 4L60e
