ac problem found what is this piece
Old 02-09-2007, 02:53 PM
jester1614's Avatar
Default ac problem found what is this piece
this piece is by the pcm and is for the ac controls
what do i call this and will just a 3 way "T fitting" work or does it have to be shaped like this? btw the fitting is broken off
also posted in general maintainence
Old 02-09-2007, 04:09 PM
Imnotfast's Avatar
its a check valve and filter.
Old 02-09-2007, 04:38 PM
streetwarrior96's Avatar
thats the the check valve the controls the vents if I am not mistaking
Old 02-09-2007, 04:46 PM
seawolf06's Avatar
If that's not hooked up, your AC won't work. I can't remember exactly how it works.
Old 02-09-2007, 04:58 PM
jester1614's Avatar
so if I go to napa i should as for the ac check valve
Old 02-09-2007, 05:03 PM
02SS#406's Avatar
I don't think NAPA will have that, but I could be wrong.
Old 02-09-2007, 05:06 PM
hashtagBMW
Speed Density's Avatar
NAPA has it.
Mine was broken just like yours.
Tony.
the_merv's Avatar
It controls the Vents also.. mine is screwed up somewhere, the only ones that work are the Winshield and Feet, and the ones in the sides of the Doors. The others haven't worked since I have bought the car. It's some kind of default setting..
Old 02-09-2007, 06:30 PM
jester1614's Avatar
cool thanks guys mine has defaulted to defroster and defroster only
Old 02-09-2007, 07:30 PM
Imnotfast's Avatar
Defrost is where no vacuum setting. Its a safety setting. Vacuum units are so 90's everything is now stepper motors.
Old 02-09-2007, 08:20 PM
the_merv's Avatar
I think the floor Heater Functions also, it was in a GM Manual.
Old 02-22-2007, 02:32 PM
emj2006's Avatar
How do u get all the a/c components running again??
emj2006's Avatar
Well cause only my windshield and feet turn on. The rest dont.
Old 02-22-2007, 02:58 PM
PunishedU's Avatar
I broke that a few months ago. Local GM dealer had it stupid cheap.
